I bet without the Bluetooth on you would have gotten another 1.5 hours just barely.
Yep.. ordered and paid for. Thanks for the heads up. At $5.00 a battery... i don't think i could go wrong.
I bought a set (two batteries and charger), too. It works OK, but the replacement batteries don't last as long as the OEM one. I can get 19hrs from the OEM battery, but only about 10 on one of those (and it had a chance to recharge from nearly dead twice).I can vouch for these batteries too.
Huh. Noticed that too with that charger. Anyway, I have the Sprint update and it still does it for me, too. I think it's doing something (ground loops?) that's throwing the capacitive touchscreen off (if you're persistent, you can get it to work a little).Oh, but don't use the USB port on the charger that comes with it. It will render your touch screen inoperable (while it is plugged in - did not cause any permanent damage). Maybe an issue solved with the update which I still haven't performed.
^that.
Your battery usage looks fine.
Until it catches fire.
