4gb or 6gb
I'm still in doubt between the non-pro 4gb/64gb and the non-pro 6gb/128gb.
The difference in price is almost 150 bucks. It's not a negligible difference.
Probably not worth it, unless you need 128gb internal.
Already have a 128gb microSD card. I'm a bit worried about the RAM difference.
Ahhh I see. Haven't had any probs with 4gb with Huawei phones. If you plan on using this phone for a long term then sure grab that 6gb. It'll be more future proof
I would not worry about it. 4gb should be sufficient in the foreseeable future. I mean if Google Pixel 2 has 4gb and is enough then you would be fine here too, at least for a few years.
Long term being relative. I would guess 2-3 years at least for 4gb. Now if you plan to keep your phone longer than 3 years then I would say go for 6gb
What I considered long term is longer than 2 years. I personally don't keep my phone that long
LayananBantuan1
