5.1.1 Verizon
I haven't received it either. I have the Verizon branded 32 gb.
Posted from my Nexus 6
I bought my nexus 6 through Verizon, and haven't received the 5.1.1 update.....I'm not alone, right??
I've checked repeatedly throughout the day for system update, but "system is up to date."
Android 5.1
LMY47E
Android 5.1
LMY47E
Yup I do the same thing all day! With the same result smh
Are you unlocked boot loader? Rooted?
I unlocked my boot loader, but did not root. Just curious if there is a connection there?
Just received 5.1.1 update. I'm on Verizon, no root, boot loader unlocked and I purchased through Motorola back in December. Hope this info helps as far as non VZW Nexus 6.
Question..... Will a notification come up showing that the update is available or just keep checking in about phone for the update?
Just got it a half hour ago.
So far so good.
Since the news only said approved not released, I guess we are still waiting for the Verizon update.
I went to Settings > About Phone > System Updates> Check for Updates
It came back Up to Date but then got notification that 5.1.1 update was available to download.
I've got the notification, just at work and don't wanna try to do it here. It will fail anyways if I'm unlocked and rooted correct?
I received my update this morning, my phone is a bit smoother.
Posted via the Android Central App on my VZW Nexus 6
If you don't have the stock recovery it will fail
I have it pending now. If anyone can show me where to look, I'd be glad to help.
Ugh. I have a VZW Note4. At 23:30 Central US time, I got a pop-up that mentioned it was optimizing apps. Now, it has been rebooting over and over, never getting past the Verizon splash page. Thanks for the brick, Verizon!
I'm lurking here to see what you guys have to say about it after the update. Just got the update on turbo and hate it. Cut my battery life in half because I can't toggle 4g off using Tasker. I also can't restrict background data. I really regret the update and am looking to change.
Sonfollower28
