Marshmallow connection issues
Hello all,
I'm "lucky" to get marshmallow update for my Droid Turbo 2. Droid Turbo 2 was my best phone ever...before the upgrade. Here you go:
1. Battery life really poor after update. Disabled wifi scanning and battery life is more or less back to normal (yet, still worse than before)
2. Nova launcher. I use central (O) button to expand quick settings. Now it expands with a speed of a snail. Nova states it's marshmallow bug which I trust because it used to work good before.
3. I use virgin pulse to sync with my max tracker. Guess what? It doesn't work anymore, used to work flawlessly before the update. Tried to sync with wife's iphone to check if the tracker works fine and guess what? It works fine with Iphone 6s.
4. And now the reason I've created this topic. My phone started loosing network constantly (I'm on t-mobile right now).
. Please find two attached images. My phone just looses network and rarely reconnects, it only works if I remove sim and insert it again or if I restart the phone and sometimes if I play with network settings changing them back and forth. And guess what? Before the update I haven't had a single issue using T-Mobile sim. Anybody have the same issue? And yes, first I went to t-mobile and got myself a new sim just in case. For me it looks like this update disabled some of the bands or decreased antenna power, or...t-mobile removed its antennas both from my condo and from my office which are 15 miles away right the day I updated to marshmallow.
Anyone with the same issues? While I can live with most of them if I don't fix the connection one I'll have to throw the phone out of the window.
and BTW, if somebody from verizon is reading this: FU Verizon and FU Verizon IT and FU Verizon 50k QA.
I've been on android for many years now, had dozen of phones and this is the first time I was screwed that bad because of an update which is supposed to add new features and make the phone even better.
Thank you.
Hello all,
Thank you.
