6.0 no option to format sd card as internal storage?
So did anyone ever figure this out I have a galaxy on5 with only 8 gigabytes of RAM and then cut that in half for the quote memory for 4GB and I have 4 gigabytes of space which is quickly used up I installed one app and cannot install anything else without wiping basic s*** constantly I bought two microSD cards and it's not letting me format them to the internal storage capacity it's only making them separate storage can we fix this or what I have Android 6.0.1 on a Samsung Galaxy on5 with a SanDisk 32GB MicroSD and a PNY 16 gigabyte micro SD what should I do
https://forums.androidcentral.com/showthread.php?t=665346&p=5112196&viewfull=1#post5112196
Just downloaded marshmallow, excited to be able to use my sd card as internal storage. However, I don't see that option. Is this a Sprint thing or S5 thing? Am I missing the location on how to do this? When I go to format the sd card, it only shows format as portable storage. Gah, so frustrating. My phone consistently runs out of space because I like lots of apps and 16gb just doesn't seem to cut it.
Having same issue on galaxy express 3
pitterhealth
