64gb sd card compatibility issues....
Has anyone had luck with the 64g SDXC card?
I can also confirm that the 64gb hdxc works. I have the class 10 model.
Sent from my SCH-I535 using Android Central Forums
From the TMO website "Up to 64 GB Expandable Memory" TMO S3
So we know officially the S3 supports 64GB cards. With that out of the way i can tell you mine has some quirks. It recognizes the card, sees the capacity, and writes to it with no issues.
HOWEVER, on the device and in explorer it doesn't show all the data. For instance all my music albums stop at the letter 'J' - I am not able to create new folders from the phone or with explorer while tethered.
It does not see it all the data in Kies either. Air or tethered. But if you take out the card and plug it into a card reader it sees everything fine and you can add and delete folders.
It is a SanDisk Ultra class 10 ($64 on Amazon - Prime eligible) I'm stumped.
OOPS. Didn't see this was Verizon. Sorry guys.
yeah i would go with the 32gb sd card because 1 its recommended by Samsung to use the 16gb or 32gb all tho some people my have luck with tricking the phone into useing the 64gb sd card or it could just be the brand of sd card idk for sure but your best bet is to stick with what is recommended and save your money im getting the 16gb S iii on Saturday and 16gb is plenty for me lol
I just bought a 64g SanDisk class10 on Amazon for$38
Never had an iphone, and don't want one. Tapatalk on Samsung GS3.
My phone recognized my 64 gig sd card (don't know what class) but my computer would not recognize it so I tried formating it NTSC on my computer and screwed up the card - now the phone doesn't recognize it - duh - what do I do now?:-\
Mine is a 64GB Sandisk, and it came pre formatted as exFAT. I had the same issue when I transferred files over: Some were corrupted, some were missing, a few did not transfer, some transferred but would not open and I could not delete them. The S3 seems to not like exFAT, so I then re-formatted the card to FAT32 and have had no issues.
Instructions
Thank you - but I finally got my computer to read exfat - I had to go to microsoft and download a patch - now my card reader reads the sd card and my phone reads it - all is well :)
So I have a SanDisk Ultra 64 GB MicroSDXC Class 10 installed in my GS3. I've formatted the card from the phone menu. Every so often the card becomes unrecognized. The native file explorer shows no content on the SD card. However, at the "storage" menu, information is contained on the SD card. After doing a quick unmount /mount and returning the the native file explorer, content on the SD card is then displayed. See the attached Images. This is frustrating because one minute you can listen to music or view photos off of the card with native apps and then next minute it's indicated as to not having any content. Grrr....
Any ideas as to why the card is interacting oddly with my stock GS3? Anyone else sharing these experiences?
Verizon's Tech Specs indicate that the GS3 supports up to 64GB microSD card.
motoJunkie1
