64gig SD card treated same as internal storage. Im running out of room even though its empty.
Whitehawk74
ASUS Zenfone 2 500.
16gig internal storage.
Hiya.
I used to be able to transfer apps to my SD card but I cannot do that any longer since an update because my phone is telling me that the SD storage is the same as the internal storage.
I have half a gig left internally and just under 64gig free on the expansion but i cannot install anything more because i do not have enough room.
All I can do is uninstall less used apps till I find an answer.
This is my first smartphone so I really dont know what to do.
I cant seem to be able to format it to something different so it doesnt treat it the same.
Any help would be great.
Thanks in advance.
hi , read that article, but still how do i change app from internal to sd or should i say i cant find the option of converting my SD card as internal storage.. :(
Jokerman
