8 Days Left to Decide Whether to Switch from iPhone to Android - Help me Decide
]It's worked well for me... HSPA on the N4 has been faster than my 4s... the only quirk I see is that simultaneous voice/data sucks and if I knew beforehand I may have hestitated... but it hasnt been an issue so enjoying the rest of the experience.
That's the first truly disappointing news I've heard. I find myself using simultaneous voice and data often. But that seems like something that could improve with future updates, right?
Yeah Like Don...I have 2 Unlimited plans. A GNexus that has Micro sim in an adapter that I can swap out. Also the Nexus 4 , With the Hspa+ sim from a Galxy S2 that I trimmed down to fit. Just because I was too lazy to go to the AT&T store, where they give you the sims for free. I did have to change Apn settings on the nexus 4.
I use both as Wifi hotspot's on occasion. Have had no contacts from AT&T on the matter. Your mileage may vary according to how much data you use.
Honestly I don't know if it will be addressed in future updates and I imagine the next update really is to key lime pie and you hope its addressed there or maybe the paranoid developer will/can address it?
Just thinking, I actually havent tested if it's a problem if you can talk and use data in a wifi area and if so how performance is? i guess i really dont use both at the same time as much as i thought. even though i probably work in a wifi area most of time, my data speeds have been so much better than the 4s i almost keep wifi off all the time.
You will not loose your unlimited data on at&t by switching devices or even switching to an LTE phone as long as you call it in and tell them that's what you are doing. The people who loose it do so because they don't call it in and switch to the right data plan for their phone
Sent from my HTC6435LVW using Android Central Forums
