A couple of questions regarding r00t for MT4G
Now all we need are some AOSP roms. The Sense interface uses up so much ram its ridiculous. With 786MB I should never be below 300.
OKAY here's another noob question. I would like to root also now that there is soo much more information on rooting this phone now but what I want to know is this...Can I root with a Mac or does it have to be a PC to do it because every time I connect my phone to the Mac I have issues with the SD Card either mounting or unmounting...now that could be a problem with the card itself but I never had any issues with the card when I used it on my Blackberry and yes I did reformat it when I got this phone from the phone OS itself. I also have the latest version of Parallels desktop installed on my Mac with Windows Vista but I cannot seem to get anything to work on either side.
If it doesn't work on either side it seems like a card issue to me. As for the Mac question I'm pretty sure as long as you can get the SDK installed and can get access to ADB in a command prompt you'll be able to do it.
Once you're in ADB it's all the same. The issue comes when you need to install programs to the Mac. If I remember correctly the SDK is the only thing that needs to be installed (don't quote me on that, it's been a while since I did it).
RichardDixon
