About Gsam battery monitor
Mar 27, 2014
14
I have installed gsam battery monitor pro and at the bottom there is a info " average per complete charge" and battery life , screen on ... actualy what they represent ? Is it the time my device screen can be on ? And what is in the bracket? Please reply
Thanks
( screen shot attached )
The average is computed from your past usage. I believe it extrapolates the total battery life that you would've had if you used the phone down to 0% (as well as the screen-on time), and averages this over time. The "Max" time for the screen might refer to how much time the screen was on maximum brightness.
Ulaburgang
