accessory compatibility between Note & Note 2? connector / dock / case / battery
12smile
Active member
May 15, 2010
35
Still on the evo but shopping for accessories for Note 2.
On Ebay / Amazon many accessories are listed as Note / Note 2 compatible....which parts are actually interchangeable.
First purchases:
Desk Stand / Charging dock
extra batts / double batts w/ enlarged cover
Extra Chargers.
Be careful, when I first got my Note, a lot of the sellers said items were compatible with the I717, stateside version, but they were really built for the European version. For some things it didn't matter, my cover worked fine, but I bought a decal set to cover the back and the front and it has a hole for the home key in the middle and icons printed on the bottom that don't match our capacitive buttons but I really liked it so I got used to it. Is the battery shape the same for the Note 2? and the charging port? If so then you're probably safe. You must be awfully anxious to get it!
I just want to sniff out the best deals....you can pay $5 or $55 for a double battery and I have 5 for the EVO.
Chris34728
