AccuBatt: 1% Battery levels for Motorola Phones
@Mooncatt
I really have ZERO idea of what could be causing this..and it seems like you're in the minority with this problem. Unfortunately, as it's not an OS malfunction specifically, I can only speculate and try to fix things one at a time. Thanks for being a trooper and helping out though!
I'll continue to fix little things that may be the culprit one at a time as time goes on.
Looks like the usage issue may have been resolved. I can't remember if I rebooted after the last update, but I did earlier today and was going to poke about but the problem never surfaced. The memory use was a little lower at 25 MB after opening the app, but processor usage never remained high. Still going to keep an eye on it, but I guess I had something hung up after updating that needed a reboot to clear out.
Well that's certainly good news! The latest update (1.2.4) should be available soon and will hopefully prevent it from happening again!
Thanks for your help :).
Actually I have tried your app and found it not to be nearly as functional as the Battery Monitor Widget Pro. It provides more features than your app, including graphs of the charging history, calibration and usage history. It also allows you to test your battery. Besides, I think plugging your app is fine, but to include the full app description from Google Play is a bit much. It is equivalent of giving us the full Monty.
Thanks for the feedback! We like to add as many features as possible when they are requested! Some features (like battery history, etc.) are native to Android so we felt there was no need to duplicate them.
I think a lot of people want a one stop shop type of interface, where they can see it all from one app and not have to hunt everything down with 2, 3, 4 different apps. And I would rather have an app with extra features I don't want/use than an app without features I would use.
Are there any specific features people would like to see in future updates?
anuragkushwaha2025
