Accubattery Users - Home & App Drawer
Hmm.. I'm not sure what you mean? Mine doesn't pop up.
OHHH..
check the settings, I see you can turn it off from your "secure lock screen"
Also, I'm not sure if you can turn it off from the notification bar through the app, but if you pull down from the top and slightly swipe the notification to the right or the left, you'll see a gear. There you can control how you see it.
Thanks man! Mainly wanted off lock screen. Don't mind the icon in the notification bar other than when phone's locked and it shows the icon on the second screen the battery percentage​ shows what the phone was last time you locked it and updates only after you unlock the device
When you switch to no app drawer does it destroy the homescreens you already set up or just add the missing apps to new screens?
It's changes a lot because all apps end up on your homescreen.
You can try it switching back and forth unless you don't own one
I have a V20. First thing I did was turn on the drawer. My battery life is good so I don't think I'll mess with it. My widgets take forever to get just right.
Sonfollower28
