Accurate Battery Mod for JT's ICS Build 6 30 Jan 2012
Re: Accurate Battery Mod for JT's ICS Build 1 14 Dec 2011
ok... so i updated my phone with this and THEN read it is for ICS and I am running SC. If you are wondering what happens when you do a bone head move like this I'll tell you. Not only do you not get an accurate battery.... you get no battery or any other notifications for that matter. I no longer have access to my notification bar.
I tried to re-flash his accurate battery mod for SC but so far no luck. Trying it again now. Maybe the second time is a charm.
In this case, I would flash you ROM again.
So will this only work on build 6 or will it work up to build 6? I am using this as a test phone and am on build 5 and see no reason to update to build 6 for just a MMS fix. But will do it if its really that much better.
Thanks
Thanks
um...idk. flash it and see, whats the worst that could happen :D
Clemens Ratte-Polle
