[ACS][ROM] Leaf Rom - 0.2
Apparently my upload speed is slower than molasses going uphill in January--with crutches! :p
EF27system.rfs
I know that feeling. :( The connection where I'm moving into is horrible. I'm making my dad cancel and let me pay for better speeds once I get settled and find a job. It won't do for my college and geeky needs. :P It took an hour and 20 minutes to upload my ED23 stock dump there
Has anyone tried using bluetooth with Leaf? On both .1 and .2, about 45 minutes after I enable bluetooth, my phone just starts running so slowly that the only real option is to remove the battery to restart the phone and turn bluetooth back off, or it will happen again. Is there any way I can troubleshoot to find out what may be interacting with the bluetooth to find out what's causing this?
What are you using it for? I'll try to mimic you and see what happens. I haven't used bluetooth since I had stock. Even then, it was just for a few quick mp3 transfers. I just have Youtube issues, but, so does my brother who still uses stock.
Ever since installing 0.2 I've had problems with a few apps crashing and/or not showing up in the app tray.
app2sd has a bad problem with force closing, and the Twitter for Android app, while running fine, does not show up in the app tray. I have to long-press on a home screen and add it to the screen that way.
Could this be something I've screwed with, or is it possible there is something screwy with the ROM?
app2sd I also had an issue with- it always crashes. However you can easily do what app2sd does as follows:
Go to a terminal emulator (you can easily download one from the market) and at the prompt, type "su" and enter.
Make sure you press Allow when the super user app asks if it is ok for the terminal emulator to get super user permissions.
At the next prompt, type "pm setInstallLocation 2" and hit enter.
This will default all apps that can install to the SD card go there on future installs.
Following this, you can move allowed apps to the SD card that are already installed.
If you can do this, I don't see a need for app2sd.
Reactions: tentonbricks
I was very excited to root my dads phone because he desperately need to use it as a wifi hotspot....well, I went to activate his phone and somehow sprint got the EF27 onto his phone....I have not idea how they did it since I denied the update...but they got it on. I tried to root my dads phone about 5 different times and it never worked although "phone info" says the leaf rom is installed. I hope I can get it on his phone soon.
...Am I the -only- person who has successfully rooted stock after EF27?
Oh, and the rooting. I did root my ED23, updated, lost root, rerooted successfully. Just did the same thing as before--the key thing for me was that the .bat had to be run twice. The first time it rebooted the phone, but not rooted. The second time it rooted the phone (and rebooted too). Needed to do that both for ED23 and EF27 hope the info is helpful ^^
Shabbypenguin and the Android Creative Syndicate
are proud to present to you
Leaf Rom
0.1
Alright lets get to the nitty gritty of it all, this is the thread where all 0.x-1.x versions will be released, as it stands right now this is nothing more then just a glorified stock, but its better then that ;). deodexing the rom allows for easier themeing so i want to see some creative **** start to flow in.. yall dont want me making themes... anyways down to the goods
Changelog:
0.2
  • - Custom bootanimations (sorry guys my graphics guys didnt have the time to make one for yall's phone.. and rather then putting this off i figured you would find one you liked ;)..)
  • - Maximized Media scanner speeds
  • - Changed out some of teh apps for slightly better apps
  • - removed sprint id and base launcher, included now is go launcher. a feature rich launcher with all sorts of cool things (and themes)
  • - Removed RescueStarter and RescueServer from the phone.
0.1
  • - Now has the latest in malware protecting (yes even the gingerbread malware apps)
  • - Sped up media scanning
  • - Added GPS tweaks
  • - Added ad blocking hosts file
  • - Enabled ADB on boot
  • - Increased max window manager events to 60 (smoothness increase)
  • - Several other build.prop tweaks
  • - Deodex'd
  • - Zipaligned
  • - Bloat removed
  • - Pre-rooted
  • - Enabled stagefright
Ok look i know yall are getting the update today and all that and so it may seem like this is kinda pointless, but firehak was nice enough to get me a copy of teh update (ill post it here in a min)., but alas its just like teh prevail and its filled with patches.. so that mean i need some brave person on stock to update and snag the base files for me.
now im sure some of you are prolly wondering what Rescue server and rescue starter are. well hidden away on the prevail i came across some interesting code for it, as it turns out its a program developed by logmein for sprint. for anyone unfamiliar with logmein, its a remote access company.
now look i understand there is porlly a 100 ways sprint can access the device and do what they want when they want. my only question is, do they really need such an obvious show of it? its constantly running (dont bother checking "running services tab" using adb shell or terminal emulator type in the following:
pidof RescueStarter
if you get a number then tada... yours is running ;). so back to what i was saying, does sprint really ned this process running in the background? i say nay, phones already have crappy life why have more crap running (hidden at that). all i did for teh rom is remove the binaries, with teh files firehak gave me i should be able to construct a odin tar for yall.
Credits:
Interdpth - For making root possible
ACS - For being a kickass team of like minded devs/themers/people
to all my beta testers for beta testing and risking their phones :D
Rodderik - for teh malware patch
k0nane - for so much help along the way
Firehak - For just being an awesome guy
hey shabbypenguin..is it possible to have the same status/notification bar from the nexus s
to be on this rom for the replenish?
it seem cool to have it..
It's possible by using the UOT Kitchen mentioned in an earlier post, but not all Froyo mods work. You upload framework-res.apk and it modifies it for you. Then you just send it back to the phone
I'm really just using it for an actual bluetooth headset. But, even if I don't connect the headset (and, in the case of Leaf .2, hadn't even re-paired the the devices) it still starts to lag around 45 minutes after turning bluetooth on. So if it doesn't happen when you turn bluetooth on, likely it's some interaction between bluetooth and another app I'm running, but only with Leaf, since this didn't happen on stock.
Just so you see a reply has peen posted, I'll double post instead of edit. I've been running bluetooth for about an hour now without issue. To make sure I wasn't lagging at all, I even streamed music to my laptop and streamed part of a movie to my phone with some VLC controller apps I just found.
Reactions: fencerjared
When you download/extract LeafRom, there is a Rom\Framework folder. Inside, there is a file called "framework-res.apk." In your computers web browser, go the the theme kitchen and start picking out your mods and theme mods.On the file upload tab, you upload framework-res.apk and wait on it to "cook" your file.
After that, you just download and extract their zip file, look for the framework-res.apk file inside the "framework" folder, and move it into the LeafRom Rom\Framework folder and run the batch script to send the rom over. If you don't need to flash the rom over, you could use my app or wait for the new version of my app that I'm putting out to customize your phone. If you need another video, I can probably do one Sunday.
The lag I'm experiencing is completely noticeable; I'm talking even coming out of lock screen takes a couple minutes. If you're not seeing it, it's probably some interaction between Leaf and some other app I'm running. As I said, this definitely didn't happen on stock. I'll start uninstalling stuff that I think might have something to do with the bluetooth and see what I get; I may even just recover to stock Leaf .2 and go from there. Thanks for your help. If I do come across the app that seems to be causing issues, what kind of troubleshooting can I do to pinpoint the exact interaction that's having problems? I do have the Android SDK, so could I load Leaf .2 to that with a virtual device and get any meaningful data? I haven't used SDK yet, so I'd need some help doing so if it would accomplish anything.
ETA: Also, now that I think about it, I only noticed the lag at that amount of time after my phone had been in lock mode for a good period. Did you try that, or was it hooked to a charger for the whole time and thereby kept awake?
I have left my phone on all day from about 90% and let it drain to about 40% battery life with bluetooth running. My phone was not plugged in for any period of time because I was moving into my dad's house today. It went into lock mode and came out just fine, I got and placed calls, used a remote control app for VLC, played a little Doodlejump, browsed Facebook and Google+, etc.. I'm not experiencing any issues at all.
I wish I could answer your question about the SDK and how to pinpoint what exactly is causing issues, but I'm pretty much an Android newbie like the majority of people posting on this thread. I got the Replenish maybe a week after it came out, and it's my first smart phone. My best advice is to do what you suggested about uninstalling apps to try and see which cause issues. If it persists, maybe even re-flash. You may have just been unlucky and disconnected for a slight period of time during the transfer and screwed up the bluetooth apk.
If you do suspect it's just the apk being corrupted, you don't have to re-flash the entire rom and factory wipe unless you'd really rather start from scratch. If you like, I can post the commands to send it with adb.exe if you don't already know how.
Re: [ACS][ROM] Leaf Rom - 0.1
How about one of those pics? Would like to post on the blog
hahah i would love to but as it seems for replenish owners many of the screenshot apps come out all jumbled and the ones that dont have a nasty blue tint all the way thru em. as i dont have this phone i cant get pictures of it as well :(
champkbillu
