[ACS][ROM] Phoenix ROM 0.2 & EXT Data
Re: [ACS][ROM] Phoenix ROM 0.2 & 0.3 RC
firehak - Did you ever get a chance to look into getting data2ext for us? What all would be involved in getting it working?
I wonder if the instructions and zips for implementing data2ext on the Optimus S would work on the Replenish (or at least provide a good starting point)? I think both the Optimus S & the Replenish have the same CPU, chipset, and same amount of ROM/RAM (512/512), don't they? I would assume both phones use the same Android partition structures.
http://forums.androidcentral.com/lg...118297-how-data2ext-reborn-froyo-2-2-cm7.html
^ I thought the same thing, and tried it a few months ago. Doesn't work, unfortunately :/
firehak has working data2ext on his phone, he was looking into implementing it as a add-on for 0.2 I think. I was looking for an update on his progress.
Will this delete the things I already have on my phone? Also I'm not tech savvy at all so would you also explain to me the pros of rooting my phone besides more storage?
It depends what you mean by "delete my things". Flashing PhoeniX 0.2 will wipe out your apps and settings, but not anything stored on your SD card, like music & photos.
You can solve this problem by backing up your phone with the free app, Titanium Backup. Titanium Backup lets you do a batch backup of all your apps, user data, & settings, to your SD card. Then after you flash PhoeniX 0.2, you can reinstall Titanium Backup from the Play Store, and then makeTitanium Backup restore your apps, data, & account settings.
But you can only run Titanium Backup if you're rooted. So you'd have to figure out how to get rooted, and I'm not sure if there's a very easy way to do that. THIS thread has instructions, but it's a bit technical. Some Android phones have pretty easy one-click root methods, but I don't think the Replenish does. The PhoeniX ROM itself is rooted (and there's a rooted version of the otherwise stock EK18 ROM on Firehak's webpage, but if you install (a.k.a. "flash") one of those ROMs, you'll wipe out your data (except for the stuff on your SD card). If you're using any of Sprint's apps, like SprintTV, NASCAR, or SprintFootball, you'd need to back those up (using Titanium Backup) from a rooted version of a stock Sprint ROM, because Phoenix doesn't have them, and you won't be able to install them (from the Play Store or from an APK file) unless you've backed them up using something like Titanium Backup. (You can reinstall other apps from the Play Store or from a saved APK file, but not the aforementioned Sprint apps that carry copyrighted media content.)
Rooting basically gives you administrator privileges on your phone rather than the guest privileges that you currently have. If you're familiar with Windows, it's analogous to having an administrator account or a guest account. Rooting lets you use certain root-required apps, like hotspot apps or Titanium Backup, and enables additional functionality in certain other no-root-required apps, like ES File Explorer.
But when you ask about the benefits of "rooting", I think you're really asking about the benefits of flashing a custom ROM, like PhoeniX 0.2. Phoenix 0.2 improves performance and frees up memory by removing Sprint's bloatware, including the incessant, annoying SprintZone notifcations/ads. Phoenix also supports a faster EXT4 file system. If you install PhoeniX, you can (and should) download DMRLook's custom kernel and his free CPU-speed governor app, called Cruise Control which let you "overclock", and set up your phone so that it automatically uses less power (low CPU frequency) when idle but gives you higher than normal performance for strenuous tasks like watching videos or playing games (though at the expense of power consumption). The bottom line is that the combination of Phoenix and DRMLooks kernel will give you more memory, higher performance, and probably better battery life.
It may be worth noting (for your future reference) that some custom-ROM developers for other models of phones add features to the phone and/or upgrade the OS to newer versions (like Ice Cream Sandwich), but Phoenix 0.2 is basically a leaner, cleaned-up version of the stock ROM.
You didn't ask about this, but I'm going to toss it out since I think it will help your understanding of the process. The instructions on Firehak's website have you download a zipped package to your PC that you'll need to unzip with a program like (free) 7-Zip. The package essentially includes three things.
1) There's a program, called "Odin" that you run on your PC which lets you load stuff into your phone via USB (not just onto the SD card). To use Odin with your phone, you need to have the proper USB drivers installed for your phone, but Windows should install those automatically. If not, they're on the Samsung website..
2) There are a couple files that flash the Clockwork Mod "CWM" custom recovery onto your phone (using Odin). A custom recovery is a utility that you run when the phone boots up (by pressing a combination of keys at startup), and it lets you (among other things) install custom ROMs & kernels which you have placed on your SD card. (FYI: For the Replenish, that aforementioned combination of keys is holding the space-key + p during boot until the Samsung screen appears. It can be finnicky so you may have to do it a few times.)
3) There's the PhoeniX 0.2 ROM zip file. You put the Phoenix 0.2 zip file onto the top level of your SD card, boot into CWM recovery and then use CWM to install the PhoeniX 0.2 zip file. You'd also use CWM to install DRMLook's kernel. (FYI: When using CWM, you use the up/down volume keys to navigate up/down, you use the back key to go back, and you use the settings key (if I remember correctly) to select.
Hi i have a boost samsung replenish i need a working rom that can be flashed through cwm or the stock recovery nandroid. My phone is stuck at the samsung screen at boot but it will load into cwm recovery. Please help!
What did you do that got your phone into this state? Did you try installing a custom ROM, or is the phone just going belly up? To my knowledge, there is not yet a working ROM for a boost replenish.
Obviously you installed CWM - is this what lead to the boot loop, or did you do something else after that?
I attemped to root the phone... I didnt get root becouse I couldnt install busybox. I then attemped to use odin to flash Phoenix 0.2 but it failed to boot. I later read it may have been for the sprint version of the phone. I can still enter download and recovery on the phone. I just want to get it back to working if possible.
The replenish says sprint on the phone and it boots just passed the samsung screen to the SPH-M580 screen and stalls.
Check around this forum - I believe someone provided a stock boost replenish image. You will need to odin that onto your phone.
I have checked all the links to the download are not working they all go back to firehak's website (for the roms) and it is down or unavailable. As for the stock rom there is some talk but the link have been removed. I have been searching for days. Could someone send it to me via email if they have it? Or the link? Please I am desperate!
I'd love to help, but I am at sprint user, so I can not get you one. Hopefully someone else answers your request.
I'm not sure if this will be helpful, but i own the boost replinish and have been running phoenix 0.2 for quite some time without any problems, the only thing that changed was some of the apps, since the rom is for sprint carrier, but boost is sprint so the phoenix rom does work on boost, and removed all the boost bloatware. It did not damage the phone, i still have all of my services and then some. Oh, If you go into cwm and wipe cache/ and or data you should come out of the boot loop.I belive i had the same problem when i first tried to install, i did a factory wipe, because it took me like three tries to get phoenix installed, but found out later it was a usb port that caused failed installation. Hope this is helpful.
Can you post the working rom you used? Maybe I am not using the right one.
Just tried to upload the rom, not sure if there's a size limit but for some reason it won't load....
Interesting that 0.2 works on Boost. Thanks for the post and having the cahones to try this on a Boost phone. I would be interested in rooting to use link2sd to install apps completely on the SD card.
I got the download but phoenix.tar isnt in the files after unzipped. Where do i get it?
Thanks guys for helping each other out while I've been busy. Things have finally calmed down again, I ended up buying a new charger after mine fell apart today ($20 effing dollars..) and I'm currently re-upping 0.2 while getting started on 0.3 once again. I should have the rest of the day to play around, but during the week I won't have much time to work on it. Though, not much time is more than nothing at all like the past few months..
EDIT: Check the first post at the ACS site for a new link. Goo.im has a much better speed than my old host, too. I think I'll have to keep using it for hosting my Android projects! The first post here should have a link to it.
mekonnen Ayele
