Add secure folder shortcut to edge panel
Really, how? They don't show in the list of apps to select from.
Do you have your secure folder visible or do you have the option selected to hide it? If its not hidden then it should be able to select......I keep my secure folder in my apps panel aswell..
I may have misspoke... What I really want is a shortcut from one of the apps in the secure folder to show in the edge panel.
I believe you can only link a task that leads you into a app in the secure folder.(Tasks Edge)..You cannot not do it in the apps edge cause the apps in the secure folder is segregated and wont show up in the normal UI
That's not gonna happen...
Edit: My bad, i just did it with fb... it's possible
2nd edit: oops, sorry wrong fb attached... the secure fb wouldn't show as an app option.. So back to my original statement...
Well, that depends. It could have still required you to provide SF security credentials to open it. Moot point now though.
guyuynhfrd
