Adobe Flash Problem for Galaxy S III
jaimanwani
Yesterday I just purchased an Samsung Galaxy S3 ... While browsing the google market I couldn't find Adobe flash .. Then after some time browsing on net and forums I came to know it has been removed since Aug 15 ... Altough many blogs suggested download Via 3 rd paty apps so I downlaoaded it on my s3 .. The thing is installs but it dosent open ... I have tried everthing in setting from allowing 3 rd party applications to enabling and suppoting flash ... Does anyone knows any other way to view flash apart from Adobe Flash player .. PS I downloaded adobe flash 10 as well as 11..m Please Help guys ..
Look up adobe flash player 11apk on google it worked for me yesterday on my wifes s3 also download adobe air it works well with flash not sure why but it does hope that helped
I solved the flash player problem.
Step. 1 download the zip file named "d3rpROM_ICS_r250.zip" You can find this rom at HTC Evo Hacks! - Best HTC Evo 4G, Evo 3D, Evo 4G LTE Hacks
Step. 2 extract the file. go into the extracted file and find the folder "system" and double click on "app"
Step. 3 scroll down until you see the apk file called, "install_flash_player.apk" copy and paste that to your memory card and install it.
At first I couldn't watch the video from dramafever on my phone, but after doing all the three steps I was able to watch the video.
GL
Re: Adobe Flash Problem for Galaxy S3...**fixed**
GL
Adobe ditched mobile flash months ago. It's no longer available in the Play Store. Just Google 'Flash 11 Android Apk" and & download from the reliable source (I'm sure a reputable Android blog is hosting the apk somewhere).
Sent From My Rooted/Modded SGSIII - If I've helped you please click 'Thanks'!
think Adobe's own site is hosting it lol :)
global s3, UK. Ask me anything and ill reply even if its just an intelligent (or stupid) guess ;)
hi, i have galaxy s3, i updated it from 4.0 to 4.1, then flash player stopped working, i uninstalled it, then reinstall it, no use, tried different versions of adobe flash player, also didnt work out, any solution for this problem? ive read that adobe not supporting android behind 4.0, but does that mean that galaxy s3 will remain missing the flash feature, i got this phone some months ago and i dont want give it away yet, so please help,
regards
Hello All,
Merry Christmas and Happy New Year ::))
I just got the S3 Model SPH-L710 Android version 4.1.1
I had installed Adobe Flash 11.1 on my phone and wife's phone (same phone) I got flash working on both. Although with wife's phone you would have to click to engauge the flash to work. Om my phone it worked without having to click screen. After a few days my flash stopped working on my phone. When I went to the icon and click it all that came up was a blank black screen. Since then I have uninstalled and re installed several times with no luck to get it to work again. The reason I had search out a forum like this to get some help.
Form this thread I had followed instructions posted by EVO
1. downloaded d3rpROM_ICS_r250.zip went to system folder then APP folder anf finally copied "install_flash_player.apk" and used DropBox to get in on my phone since it was easier working from my desktop to get to this point. From Dropbox I clicked on the file "install_flash_player.apk" and I was asked if I want to install which I did. It said it installed successfully and the Flash Icon appeared on my phone as before. I got same problem when I click on icon no setting show up all I got is a blank black screen. All this time on my wife's phone Flash is still working from the 1st time installed. Anyone with any ideas whats going on?
Thank you
Rif
Thanks a lot. .it was useful and I recommend it for other and it will take several clicks and couple of minutes. .Cheers
- - - Updated - - -
Cheers. .mate
Having a similar problem. I viewed a couple of flash based videos yesterday. Also had flashplayer listed on my menu. Went back to s flash I shared and will not play now. No longer see player on phone eithet. I did not erase it.
TOOLS
