Advanced Problem - Cannot Use Half of Cameras
Penahi
I first should say that I'm not a newbie, yet also ain't a developer/coder. And as you'll see if you'll care to read, I did all the basics.
Long story short, I'm using a Redmi Note 8t. It's unlocked and rooted. Yet, don't know why exactly, I cannot use front and Wide Angle cameras. Macro and depth sensor work fine, as does main camera.
I tried all I could find:
Clearing cache and data.
Trying with different camera IDs.
Using third party camera apps.
Reverting to stock ROM.
Using different ROMs.
Applying two patches.
Messing with permissions with permissiver.
I doubt that it's a hardware issue as both cameras stopped working at the same time.
What might it be? I don't seek only a solution but some hint at least, to have some starting point.
Any ideas are more than welcome, and thanks in advance if anyone cared to read and would care to give any opinions.
Have you enabled auxiliary cameras in the advanced settings?
I did. Sadly :(
What's strange is that the macro cam works while front one doesn't. I mean, it should consider macro as aux cam rather than the front. Isn't this kinda insane?
Addition: I used Arnova's patch, and it broke the setup even more actually :D
I tend to believe that this is a hardware issue but cannot explain how these two broke at the very same moment without the mobile being dropped or anything.
omgitsjoshitos
