Advanced Task Killer for FROYO
Remember that you do not have to have ATK set to automatically kill.
System Panel does exactly this and adds the history to show you what is really taking your battery.
ATK GARBAGE needs to be removed from the market !!
Too many new and unaware
Android users put that crap in their phone, only for it to cause problems
perceived as "Android issues".
It's getting real old !!!
I can't find system panel anywhere in appbrain.
Nevermind it's one word.
Anyone think this may cause a conflict with stats?
so sweet when my posts get deleted. if you look around it had just about as much substance as the rest of this garbage thats been repeated a million times. but whatever. sieg heil i guess.
This is the program I use to monitor for run away programs:
Watchdog Task Manager - Android app on AppBrain
Essentially, the program takes a "snapshot" of CPU and memory usage at intervals you decide. If a program is detected as using too much CPU or RAM, you are given a notification and asked, "What do you want to do with this program?" Ignore or KILL. This is all I've ever used and as long as I'm in a place where I get a good signal and don't play too much Angry Birds. My battery will last all day.
It's just a couple bucks and there's a lite version too.
When I was reading up on Android memory management, I came across a great saying to describe it. "Free memory is wasted memory." Get out of the Windows XP mentality of memory management and welcome yourself to 2010 Android!
I read through the last few posts about task killers and the last post was Oct 2010. I received my Dinc in Dec 2010 and had the ATK installed by VZW. After reading through everything has anyone's opinion changed about ATK since Oct 2010
Thanks
Take ATK off your phone!!!!!!!!!!!!!!!!
Get the idea?
Not meant to sound rude, ATK counter acts what feoyo is already trying to do.
Reactions: Bucsfan76
jocar37
