Advantage with OTA 2.2 vs. leaked 2.2???
Someone clear this up for me: When the OTA 2.2 does launch for the X, and it appears on my device, do I have the option to NOT download it???
you should be able to just say cancel or close or whatever.
but it will nag you until you download it
hopefully the current method that works on the leak as well as the droid 2 will remain viable.
I hope so, I went ahead and went crazy (you guys ARE crazy) we're all crazy..........anyway, got the leaked 2.2 w/root and uninstalled some bloatware, (yeah I know, should of just renamed to .bak) but now that they're gone could I still update to the OTA 2.2 from my sd card? (what the hell does OTA mean anyway?) plan on waiting to see what everyone thinks of it first.....
removing some key apps might not let the OTA install properly, but if you're comfortable enough with your phone to load a rom and use clockwork mod, then it's probably best and not detrimental to your life to wait for the feedback regarding root and whatnot anyways
Way cool, loving the android life my friends!
Sent from my DROIDX using Tapatalk
IamHg
