After a full charge my Samsung S4 will not turn on, how can I get it working?
  • Start date Start date
A
AC Question
after a full charge my SamsunS4 will not turn on . Green light is on
no matter what button I push nothing happens . Do not know how to remove the back to check the battery
Re: after a full charge my SamsunS4 will not turn on . Green light is on
Looking at the phone, face on...on the right hand side above the power button you'll see a small bit of the back part cut away. Use your nail or a blunt tipped blade to prise the back cover away.
Battery just pops out then.
Hope that helps.
sukotgu2
