Airrave Location Problem
Aug 3, 2010
5
Just wondering if anyone else had this problem, I have 2 airraves, one at my house, and one at my girlfriends. When my phone is on either arirave it shows my weather location as a city approximately 100 miles away(same city regardless of which airrave I'm on, and both airraves are physically located in different cities), and I firt open any other location based program is shows the same location until it gets an accurate GPS fix. Anyone else have a similar issue?
Does it report the same thing if you're connected to the cellular network of wifi? Turn of GPS and see if it does.
Yes shows the same thing with wifi on and off, and gps on and off. I'm sure it's pulling the location from the Airrave, just not sure why 2 different airraves, show the same incorrect info. They are also 2 different model airraves, one is the original model, and one is the plus. Both indicate they have a valid GPS fix.
Airave makes a VPN connection so it shows the location of that connection. For me it's a city about 60 miles away. I have times where it shows the right city even with being on the Airave.
visionarysearchist
