Already have screen burn on Note 10 plus!
  • Start date Start date
I have this setting enable on my Note 10+ and can confirm that a screen saver comes on during charging.
Those that don’t see screen saver I’ve tested this for y’all ...if I use power button to turn off screen while charging battery percentage stays ..if you let screen timeout then screen saver kicks in
The charging-battery-percentage doesn't move around like the AOD image does?
(I've never had burn-in from anything except Google Maps, back on the Note8, from keeping the screen on for hours in bright sunlight while navigating.)
It does but with a lot less variation than AOD. Even the FPS locator moves slightly every time plus it has the animation when pressed on.
Is there a black screen saver that can be used? I only see options for colors and photo rotations.
Create a folder or album within your photos with a black wallpaper .. then select photos and choose that folder / album for the screen saver..
Following this thread but confused as to what to do. Is there really a risk of burn in from using the wireless charger overnight? I see that we can select the screen saver while charging although the options are fairly limited. Is running the phone all night long with the color shift preferable to just leaving it as is. I find it hard to believe that Samsung would misfire like this and allow burn in. But, owning a 65 inch LG OLED, I realize that burn in is real and I am very careful to protect my TV from it. Any other options? I tried the AOD clock setting last night but the charging message remained at the bottom so that's out.
I don't charge my device overnight anymore, mainly because there is no plug on my side in our new house but also the Note 10+ holds a great charge and since it charges fast, I just charge in the morning before I start my day.
I use Night Clock app at night while it's on the charger. Fully customizable and the clock moves around the whole time. I've been using this app since the first year of the Note 8 when I got burn in. Never had a problem since. I also use Wallpaper Changer app which rotates as many wallpapers as you feel like loading. My wallpapers change every 3 min.
Please link to app. There are several called that.
I also use Alarm Clock Plus and have Bixby turn it on automatically when I place it on my charger during the day. Fully customizable and it also continually moves around. Wallpapers still change every 3 min. Screenshot_20190903-192303_Alarm%20Clock%20Plus.jpeg
majifats
