Always on display wireless charge question?
felloffthetruck
Trusted Member
Mar 31, 2013
8,616
22
38
I have my AOD on and the whole time I'm charging the phone wireless the status and time left are displayed across the bottom of the display.
Is this normal?
Will it cause burn in as this writing does not move around like the AOD does?
I find it odd how similar info is also present if by the battery level icon if that's part of the AOD you use.
I don't think it would really cause burn-in as it's likely moving just a few pixels every now and then.
animats
