Android π beta registration is open
Carriers are already pushing out the upgrade for S9 and S9+ So it should be soon for the Note 8. We're suppose to get it some time this month... Makes no sense to do the beta now.....
Makes perfect sense to us
Why do the Beta now when it's coming out later this month? That's stupid because it won't be easy to revert back to do the offical upgrade. It would require using Odin and flashing it. Those people will be stuck with the Beta version with no way to get the final upgrade....
Couple reasons.
Because I can.
I like the idea that my, and other users, feedback will, maybe, be used to improve the UI.
If you know how to run a beta then you must likely hope to revert and Samsung makes it easy with the beta.
Couple reasons.
Because I can.
You got a good point with being able to give feedback to Samsung. I would love to do the beta and even had the downloaded file on the phone. It's easy to do the upgrade through the phone but it isn't easy reverting back to get the final version later on. That's the main problem. Plus I been hearing you can't use Samsung Pay with it. The final version comes out either this month or March the latest. Better off waiting for it
Samsung pay works fine, for me. But some have reported problems, same with Google pay
Just got a update email about the Note 9 getting the upgrade now. So the Note 8 should get it this month. Sammobile reported it.
caritas
