android 10 One UI 2 is official for our beloved Note 9
My unlocked is running on T-Mobile, no update. I see AT&T folks are getting the update, so I switch out for a AT&T sim, and right away getting the update. Thanks
Installed it on my AT&T this evening, checked everything, updated all my Apps but then noticed my phone signal had taken a dive after the update. Rebooted with a "Clear Cache" and still, same crap... at home, with Android 9, I used to get 4 to 5 bars of 5G, constantly! Now, I'm getting 1 to 2 bars in the same place with the same phone after a simple OS upgrade... DAMMIT!!!
Try resetting network
Your Note 9 received 5G?
"Johnston212 - yep! I agree - I just fired off an email to my Alarm Clock App developer for help... it's staying buried in the background since the update! "Do Not Disturb", for as long as I can remember, had a feature, which I of course depended on, where you could set to allow "Messages" and "Phone Calls" but from "ONLY Favorites" in your Contact List? I put my Family and close friends in there in case of Emergency during the night? GONE!!! Phone rang this morning at 4:00AM... Telemarketer that got through my "Should I Answer" App, which works 95% of the time... just not at 4:00 AM when I needed it (or maybe it's another Android 10 glitch) Oh shut up Jim!!! You're starting to sound like a grouchy 70 year old man... oh wait, you are!
-snip-
Really? It's no issue for me. Bear in mind I'm using the stock alarm clock.
Yeah, this is "AlarmClock Extreme - has some super features an I've been using it since my Note 5, if you can believe that! Multiple Alarms for Meds different times throughout the day with soft music rather than a ringer, gradual buildup to volume, etc.
My issue is that I also needed to reset my smartwatch, but I waited until after the update. It gets stuck at the setup stage. Now I have to go to work without a watch.
websitedesig102
