Android 10 OxygenOS 10.0 update for OnePlus 6 & 6T
Re: [*NEW*] Android 10 OxygenOS 10.0 update for OnePlus 6 & 6T
Confirmed working on T-Mobile conversions. I flashed it myself
Did you just do the normal download and local update? I might do mine but want to make sure I have everything I want backed up just in case.
That method has been working perfectly for everyone. I did it a little differently because I also flashed twrp and magisk, which currently is a little tricky on Android 10. However if you are stock, just flashing the local update is all you need to do
I just flashed to the Android 10 on my T-Mobile conversion using local update.
So one thing I'm seeing weird with this update is there is an Android system webview update that is stuck trying to update.
Hi guys, I went ahead and did the 10 upgrade using the Oxygen updater. So far, so good. I have the One Plus 6T unlocked model.
I'm using the stock launcher and wanted to know if I'm using the option to have No app tray, is there a way to sort the apps alphabetically? I know I can arrange by hand, but that's not optimal.
And no, I don't want to use a 3rd party launcher right now.
drayb
