- Feb 6, 2017
- 99,160
- 15,889
- 113
- Open call app
- on top right corner, tap on 3 dot > Call Settings
- tap on "Make calls by"
- Select "Call icon"
That's all you need! The default setting on new Android upgrade is set to "Call log entry" by default...
Good luck!
Hi, welcome to AC!As I posted above, it's not a bug, it's small little thing in settings, not sure if it was there in previous versions of android.
What Samsung model you have and carrier?
