Android 13 Beta 2
Well I got jinxed today, after 2 days on this the phone call bug reared it's ugly head for me today. I shouldn't have commented earlier.
That's one of the frustrating aspects of some of these bugs, not .affect all users all of the time. Inconsistency seems to be the operative word.
Yesterday I was on an hour long conference call and the call quality was perfect. No screeching sound or distortion. One consistent issue is the delay in call connection resulting in the greeting "Are you there?" Grrr!
Not to belabor the Search blank screen issue but it is a known issue for some but not for all.
https://developer.android.com/about/versions/13/release-notes
So I opted out for now until they fix the call bug. I was pleasantly surprised, especially after what they did on the beta 12 builds, that you can opt out and actually go back to official build. It wipes your phone but I didn't care about that as much.
I'm going to stick with the A13 Beta builds. I'm a sucker for punishment.
Have had a couple of random reboots now but not while my phone was being used.. Picked it up and needed to enter password to open it...
That's one bug my phone hasn't had on A13B2, no random reboots.
Yep, I had a few of those as well. 1 was while using it, it froze and rebooted and the other time I looked over and saw the boot animation screen.
Still working pretty good for a beta tho, have now installed the same on my P 5..
Installed it last night. Seems to be running ok. Filed my first bug report though. Wanted to pin the Rangers playoff score from Chrome. It pinned, but only showed a partial image. Otherwise functions like before. Also, when I g to the update screen in the settings is says Android 13 in the System screens but Android 12 when I tap on it as if I was checking for an update.
It will probably show 12 until the official A13 is installed. I'm on A13B2 and it shows 12 as well. Nothing to be concerned about.
Not a real issue but I reported it and Google has assigned it out. This did not happen when I was on the 12 beta last year....
Another bug I reported, though it appears someone beat me to it.
The temperature on the lock screen and the home screen does not update when you tap on it to go into the app. Just stays on whatever temperature it wants to. Right now it says 57 on my lock screen but in the app it says 63.
If I open the weather widget the temps then correctly change on both lock and home screens on my 4A. So not seeing that issue.
They both will change without opening the weather app although the update intervals are a bit slower.
Has anyone else noticed heat issues while using the camera?
My Pixel 6 Pro hasn't had any heating issues running A13B2. In fact after the Search bar issue fix I haven't noticed any obvious bugs or issues.
araelbenjie
