Android 16
I was on QPR1 Beta 1, I thought I will be upgraded to the final version but I just checked and it's downloading QPR1 Beta 2, what gives?
You were given the option not to upgrade when QPR1 came out. You didn't read it and took it. Doing so you entered into another beta. Only way back now is to wipe
So 3 days later no prod stable 16 update. Kept telling me I need to wipe my phone and go back to 15. I ended up installing QPR1 beta update. I'll run it until when the next window is.
Didn't want to wipe my phone unfortunately.
If you hadn't told me my phone updated to a new OS I'd have had no clue. It prompted me to see if I wanted to enable the battery saving stuff, but otherwise I haven't noticed anything different. 🤷🏻‍♂️
Reactions: 1Coopgt and srgonu
Most dumb major release across products ever.
Nothing great about android 16 because they left out a couple things like dex mode similar to how Samsung connects to a monitor and Material theme that changes the UI look, these are available in Beta
Anyone else notice Now Playing is very buggy since the update? A lot of times, nothing shows when music is playing unless I toggle the setting for it off and one again but then a few minutes later, it again shows nothing. Now Playing History is blanks, I cleared the cache for System Intelligence and restarted my phone several times now but same thing happening.
It's the foundation for what's to come. So on that note, yes it does have some worthiness to it.
So silly question. Normally Android releases their OS updates late fall December time frame. What's up with them releasing 16 in the Spring?
noroldie
