O OT77 Member Jun 10, 2016 14 0 0 Jun 10, 2016 #1 Android Auto does not work Plug phone in and no connection. Have Lollipop 5.1 app is installed. Get accepted cars none, rejected cars none. The one button does nothing.
theelite1x87 Trusted Member Sep 23, 2010 552 1 0 Jun 10, 2016 #2 Re: Android Auto does not work Ok. What phone? What head unit? Did you make sure the usb settings isn't set to charge only or something?
O OT77 Member Jun 10, 2016 14 0 0 Jun 10, 2016 #3 Re: Android Auto does not work 2017 Ford Escape with SE Technology Package. Phone LG Rebel LTE. Have to check USB settings.
O OT77 Member Jun 10, 2016 14 0 0 Jun 11, 2016 #4 Re: Android Auto does not work Had to update head unit. Use phone supplied cable. Now have Android Auto.
theelite1x87 Trusted Member Sep 23, 2010 552 1 0 Jun 12, 2016 #5 Re: Android Auto does not work Awesome. Glad you were able to get it going
O OT77 Member Jun 10, 2016 14 0 0 Jun 12, 2016 #6 Re: Android Auto does not work Thank you for the reply.
O OT77 Member Jun 10, 2016 14 0 0 Jun 15, 2016 #7 Plug in phone and not connecting every time. What are the steps for connecting phone?
bjrosen Well-known member Mar 19, 2011 751 3 0 Jun 15, 2016 #8 I plug in after the display powers up. If I plug in when the car is off it doesn't seem to see AA.
O OT77 Member Jun 10, 2016 14 0 0 Jun 19, 2016 #9 Still problems . Reset head unit, boot phone, deleted apps for more storage. Worked 3 times.
O OT77 Member Jun 10, 2016 14 0 0 Jun 19, 2016 #10 Get message cannot sync android auto check device settings. What setting do I set?
O OT77 Member Jun 10, 2016 14 0 0 Jul 21, 2016 #12 Three times AA worked Plug in when the car is off and AA works.
