Android auto help
Kitty1233
6
Hi up until recently I was able to use android auto in my car. A week ago it stopped working just a message on car computer screen saying no media data from usb. It's asking to connect a compatible device. I haven't made any changes to my phone etc. I have changed the data cable. Reinstalled AA. Turned fone off/on. Deleted the cache etc. I have read there is a problem either with Google or AA. All I use it for is the navigation on my car computer screen. Is there even an app I can use for this? I've tried to use Waze but getting the same problem. I'm using an Huawei p30 Pro with no problems until now. Thanks
Are there any problems if you connect your phone to a computer? If so, there might be an issue with the phone's USB port. Use a can of compressed air to blow it out, and a small Q-tip dipped in rubbing alcohol to clean the contacts.
I have a p30 Pro and untill recently my android auto was working in my car. Now it has stopped. Even after getting the new android 10 update still no difference. It's displaying on my fone just not on car computer screen. It keeps saying MEDIA ERROR and NO DATA ON USB . Any ideas?
Duplicate threads merged.
Do other Google services work on the phone, like Gmail, Google search, the Google Play Store, etc.?
PeterHerre
