Android Logo Wallpapers
As stated before....if you let me know which one you want resized I will do it for you. I have the original files and can enlarge them so you don't lose any resolution. Otherwise try the above method. If they look pixelated or fuzzy let me know and I will resize them for you..
EDIT: ALL Images Have Been Re-Sized To 960x800
Cyber, your are awesome!!! Freaking awesome! Thanks a million times over and over! :D
edit*** any way to resize them for a DX? Thanks!!! :)
They are sized for a DX. Long press over the image and set as wallpaper. If you need Lloyd moved around because he's in the way of something on your screen, let me know.
Yea I did that. I guess I was used to how the "Official"(ones on the main site) wallpapers look with Lloyd in them, with these they don't look as "hi def" when I set them as wallpaper. Either way I'm blown away with how they look.
I Will Be Going Through The Wallpapers One by One And Resizing Them To The Correct Size Of 960x800.
If you need something re-sized before I get to it, send me a pm and I will re-size it for you.
EDIT: All Images Have Been Re-Sized To 960x800
Thanks, Cyber Warrior. Really love what you've done thus far. And for me, resizing them on my own from 960x854 to 900x800 should be great with not much, if any, loss in quality.
Appreciate it!!
Said it once, I'll say it again. Thank you so much CW for taking the time out of your day to make these wallpapers for us. :)
Reactions: Cyber Warrior
I Will Be Going Through The Wallpapers One by One And Resizing Them To The Correct Size Of 960x854.
Thanks for doing that. Just love your wallpapers and want to use them with my EVO. I can wait.
Sent from my HTC EVO 4G using Tapatalk.
Android Logo Wallpapers by Cyber Warrior...
Wallpapers can be customized to your liking: Names, Colors, Logos, Sizes, etc... basically anything can be changed or re-arranged.
:) Custom ideas are welcome. Either PM me or Post a detailed description of what you like. :)
:cool: Show Some Love & Hit That Thanks Button :cool:
Ashok Dharshan
