Android N Battery Drain Need Help!
Vfrenchy French
Hi, do we're all aware of the android N Battery Drain issue, I've been experiencing this issue since updating over a month ago. I'm using the LG Stylo 2 LGLS775, which runs a 3000 miliamp battery, my battery life has decreased dramatically. I've included two screenshots below. I've made a complete phone reset before making this article and tried resting all app preferences before that, which i heard may help the issue. Someone please help out if possible, I'd really appreciate it. Thanks in advance.
Welcome to the forums. You could try a cache clear, although a reset should have taken care of that part. You can do that in Settings>Storage. Click on the cache section. Afterwards, try a reboot
Wipe the cache partition too. You may need to Google the instructions for a LG phone. I don't know if it's the same as the Nexus/Pixel line or if they changed it as Samsung did
Jake2H
