Android OS is killing my Note 3's battery
ZarathustraHead
325
Over the course of about the past week or so, Android OS is killing my Note 3's battery. Sometimes a restart will cure it until the next day when I take it off the charger - at which time it will typically recur. Sometimes a restart will not help. I've audited and removed a number of apps, but so far I haven't been able to cure the problem.
Is anybody else having issues?
I went into setting and change a lot of it as well as turning off a lot of the settings. Example: gps, wifi settings, application manager to force stop a few of them, turning off all motion control expect air command, little things like that really add up. If you use them, then keep them on but if not turn it off. Dim your display. You'd just have to play with your settings. There's no real cut and dry answer for this.
Sent From My Samsung Note 3 using Tapatalk
Ruby_OS
