Android P (Dev Preview 3) -- Live!
Status
Not open for further replies.
Mine has failed to install twice now
Mine also failed twice. Both times it was right at the end of step 1. Third time was a charm, although step 2 seemed to take forever, but that was to be expected as I saw a number of comments about step 2 taking quite a long time.
I had the clock on the status/notification bar displayed with "seconds". I've lost this in the DP3 OTA update. System Tuner UI is no longer available o change the time format. ANyone know how I can get it back? TIA
If it's available there must be a new trick to activate it - the old steps don't seem to work.
Yeah mine failed right at the end of step one/beginning of step 2 and then worked the 3rd time as well. Step 2 didntake a little longer than usual.
It's on the always on display. As I said, mine would work for a while then disappear on DP2 but come back by uninstalling Google app updates, but in DP3 I can't seem to get it to work at all.
Things I have noticed. My LBC radio app now works as intended. Yippee!! And despite Barclays Bank claiming not to support beta software, I can now login to my bank account using the Barclays app!! So already winning with this update. Seems stable so far.
I noticed my "HiYa" call blocking app doesn't work but worked before today's update. No biggie, but curious why now and not before.
Read somewhere the "camera laser sensor" is available in dev options since "P". Checked there and see it is enabled by default now. Not exactly sure what it does.
Yes, Barclays UK stated that their banking app would not be sorted til the official P release(tossers) but it now seems sorted with this new update
Am pleased. Had to put it on ny husband's phone to use it.
This release has a lot more compatible apps.
Anyone having an issue with the "double swipe up" to open the app drawer? Mine will not move off of the 'recent apps'??
Nope, nothing! The only way into my app drawer is to disable 'Swipe up from Home button' and use the old method...
Weather isn't showing on the lockscreen for me. Not sure what's up with that, would be awesome if it would. I had a heck of a time getting this running. I had issues with the stable June update so I did a factory reset for the third time and signed up for the beta again. Could not get this to setup on wifi, would not let me go past the wifi screen, I could log in, but not move past it and I couldn't get it to forget the network. Was able to reboot into safe mode and get through it, reset again and just used mobile data for the initial setup and got through it.
The brightness is weird. Almost blinded me this morning but got really dark after that. Otherwise it seems pretty solid and is running fine. Going to give this a couple days and see how it goes.
The issue seems to be with the Launcher. The 'Swipe up' works in Pixel Launcher, but not in Nova. Is there a Nova setting that will help with this?
That was my next question which I probably should have asked first....if you were running a launcher. I have Nova but I don't use it with Pixel.
If you have Nova Prime you can enable Gestures to do what you want. I was able to use swipe for recent apps and two finger swipe for app drawer. Not the same exact thing as Pixel but it works. You can also use others gestures instead.
Anyone else notice the volume buttons only control media volume and not ring? I can toggle ring between on (current volume), vibrate and silent but can't change the level. Am I missing something? Pixel XL.
I press one of the volume buttons and a small menu pops up. Then touch the settings icon and there is all volumes settings. I actually like this and have gotten used to it.
Status
Jackwills2567
