Android studio problems found while loading plugins how to fix
Giannis Mariettos
3
I have a problem and i cannot open android studio at all, it says "plugin Plugin 'Code Coverage for Java' wasn't loaded because loading of plugins is explicitly disabled in the current instance of the IDE"
It's the 1st time to see this error so, what's wrong with it?
Hope you don't mind, I moved this to the Developers Lounge, since you're talking about Android Studio.
If so, just enable that plug-in. :cool:
Go to File - Settings - Plugins, select the plugin 'Code Coverage for Java' and enable it.
devon9
