Android system killing my battery.
Jannukaz
24
Hey there! Yesterday I saw that my phone has lost some battery fast. I looked into battery and saw that "Android System" was at 45%.. That's a lot for me..
I've had these problems before. Before I've had media server battery problems and Android os battery problems. I've found a fix for them on the net though, but, not for Android system..
So.. Any help? If you need any info I can give you everything I can. I can show screenshots later if needed.
Android system : cpu total 2h 5 min 52%
Stay awake 7m
Screen : 8h 30 min 25%
Thanks for any help!
Same issue here... Following. I reformatted my SD card and wiped cache partition and that worked for a day but back to square one now. Very annoying.
Boom! From My S5
uploadfromtaptalk1424544726355.jpguploadfromtaptalk1424544735272.jpguploadfromtaptalk1424544741718.jpg
Some screenshots. Also, I've already disabled the Samsung link things, it worked for a while, but the battery hog unfortunately came back.
Sent from my Galaxy S5
ok unmount your SD card and then remove it see if it will runs better for a little while remember to unmount first or just power your phone completely off and take it out.
Figures... :(
I'll look deeper into this & see if I can help out. Oh It could be WiFi lte constantly switching on/off searching. are you on the Verizon S5 by any chance?
Maybe try enabling developer options and then going into background processes and limiting it to two running at the most.
that's usually the last option and it usually works.... I still think its a Samsung process running away in the background but I bet you've been through all that already :(
if you go for the factory reset just remember to be sure to backup all your important stuff ;)
johan mayhew
