Android System used 20% of battery!
prissysox
Trusted Member
Jun 11, 2010
1,246
12
Phone was idle, connected to WiFi. Updated to 1.85 that morning. Checked battery usage after Wierd drain and surprise, sunrise Android used 20% of battery. WTH? Anyone else have this issue? Never happened to me before
Sent from my HTC One X using Android Central Forums
You have a rogue app that you installed running.
Sent from my DROID RAZR using Tapatalk 2
What was the total percentage of battery use? You have to remember that the 20% is only 20% of the total. So if total use was 15%, then Android OS used 20% of that 15%, which would then be a small amount of the total battery usage.
Ayomide
