AndroidPie on Note9 1st impression...
playernaresh
3
Missed some of the best features of goodlock apps after upgrading to Android Pie... Also, after upgrade, I'm getting problem with touch sometimes and little more battery drainage...
24 hours on Android Pie with One UI. No touch issues. Battery life definitely hasn't reduced. Loving DARK MODE. Wishing it affected all my apps. I'm not a camera person. No glitches so far (and I'm yet to do a factory reset)
7 days of being on Android Pie One UI. No complaints. Haven't noticed any change in performance. Did a factory reset 48 hours ago. Battery life seems the same. Still early days.
A couple of questions.
Is anyone using a Note 9 Hybrid version with x2 sim cards in it and updated to Samsung One Ui.
On oreo a box used to encase the signal option I was using in my status bar as two signal strengths show and as of now the box has disappeared.
Also on opening up multitasking I could have a list view and now it's only a card view - is this changeable?
Few days with Pie. So far so good. Battery life similar as Oreo. Really smooth software. UK with EE.
I have the hybrid version but am only using one card slot with a memory card in the other. The recent apps card view can't be changed to the list view.
RobKe11y
