Annoying Bluetooth Disconnect Notification...How Do I Disable it?
no doesn't appear to happen in safe mode. I have gone through all my Apps...it did just happen again while connected to the BT speaker (no disconnection this time)...soooo frustrating!
I have bought a zip drive-will download my phone and factory re-set...only thing I can think to do
You have lot of apps ?
Another thing download from galaxy app store a app called Nice Catch help determine what app it could be .
So this happens only when you're connecting to your bt speaker? Do you have some kind of app to control the speaker? You could also show a screenshot with currently running services if you have developer options enabled.
Factory reset seems to have fixed the issue...fingers crossed...thanks for all the suggestions
MisterVoltio
