Any call recorders that actually work with the Note 3?
Kindly advise me on the above subject because I have failed to install a programme from PLAY STORE to record the calls on my Samsung Note 3.
RMC - Android Call Recorder
I use it for business AND it is excellent. Works great on my VZW Note3 (SM N900V).
It's free and is amazing.
Good luck. Peace
PS: no root required!
Joee0201, in Wanam Xposed, go to the Phone menu, check Enable Add Call button, check Enable Call Recording Menu, then uncheck Enable Add Call button (the two are mutually exclusive). The Call Recording menu will then be ghosted but active. I've recorded several conversations and it picks up both sides. Make sure you reboot after enabling (as prompted). Good luck!
Galaxy call recorder worked for few days .. recorded 4 calls ... thereafter calls were being stored in mp4, though 3gp was chosen in the settings .. because of this I am unable to replay it. If you had the same issue and found some solution, please share with me. Thanks in advance.
Acr call recorder is not working.
why any call recorder don't work on Samsung galaxy SM-N9005 NOTE 3?
Takyi Benedict
