Any Charging Screen Burn In?
The charging info showed up on the N10 series...wasnt there on the N9/N8/N7... I even made a thread about it... Only way is to disable AOD...
I don't use aod and it still wants to show so I disable it.
I'm exhausted and sick so may be remembering wrong about the battery info on the others
I really think we can put to rest about anything being static on the AOD screen. Everything that Samsung puts up on the AOD screen moves a little. You don't even have to stare at it very long to see it move. I am surprised that people still have this question after AOD has been around for so long. Even with the new charging info on the AOD screen, it moves. It would be silly for Samsung to design everything to move except that info? lol
The only instance of screen burn-in I've seen on these forums is the one where someone seemed to get it from the navigation bar at the bottom. I think that was the Note 9 or S9 which I am guessing happened because of constant high brightness and using apps that had the navigator bar up constantly for a very very long time?
Well, i paid USD$1200 for my N10+ and i just want to make sure. As burn in IS NOT covered by warranty by Samsung Electronics Indonesia...
Here in the US you have 1 year manufacturers warranty, if you develop burn in that should be covered under a screen defect in that time frame .
Here's a way to disable it, but it will disable AOD completely.
Install following
https://play.google.com/store/apps/details?id=com.ccswe.appmanager.samsung
Follow these directions
After installing the program, open it up go to Always on Dispaly , open it up then go to services , then choose Battery alert hide intent service and click it to open it and at bottom of screen chose disable service then go to PluginAOD and open it and choose disable service. and that was it. hopefully this helps.
It works, but like I said, it disables AOD also.
Not in Indonesia... I forgotten which Samsung it was but i had dead pixels and they wouldnt swap nor repair it for free...
Most recently my friend's S10+ had burn in because of playing too much Pokemon GO and had to pay USD$200(screen) and USD$32(battery)...
Replacing the battery is compulsory in Indonesia...
So its been a few months since the N10+ was released. And at first i was afraid of the AOD Charging Notification Burn In.
So im wondering anyone have burn in yet? Or does the Charging Notification move? Because im planning to turn AOD on again...
It won't burn in. It moves constantly.
Oh wow ..
tedswoodworks
