Any downsides to lower to 0.5 the animation scale setting ?
On the first day with my phone, I set all 3 to 0 and couldn't figure out why I couldn't long press on home screen to get popup with choices. Read somewhere here on the forums that animator duration needed to be set to .5 to get that option back. I changed that one to .5 and had the long press popup menu again.
Last night I set animator duration to 0 (all three on 0) and still had the long press menu. Not sure what changed but something did.
Yeah, Samsung fixed that problem on a recent TW update. I'll try to find the thread and post it here.
That's probably it since I installed the latest TW not long after I changed the one setting back to .5. I couldn't remember what might have changed on my end.
another weirdness about this phone. I keep setting all three to zero, or two to zero and leave one .5x, and when I go back in it has reset to value of 1x on two. I'm going to have to do a FR to cure it one of these days.
what about moving icons on the home screen? others and I have had issues removing, uninstalling icons, etc. due to long press being absent.
Yeah all works great on mine. Guess it is from the update that was posted earlier. I always keep mine and .5 anyways so didn't notice your issue. I saw other poster post about not being able to do it on 0 and tested it and worked.
...and to make it short and sweet, it supposedly helps to clear up the "Lag" that some people whine about, which, in fact, I have NEVER noticed to begin with, as far back as the Note 5???
Not needed on Note 8 to be honest. Phone is so freaking smooth. I'm good.
It's also what Apple did to their phones many years ago to speed them up. So no I've done it years no problems
If you use the default Samsung email app (which I have to use for work), there is still another problem with leaving the Animator Duration Scale at 0. It may be a minor issue for some, but caused me some headaches. In the details section of an email, it prevents you from being able to see all the recipients of an email.
I posted it here:
https://forums.androidcentral.com/showthread.php?t=834514&p=5986960&viewfull=1#post5986960
I posted it here:
Great tip! I've seen different issues related to these animations, but didn't know about this one. Thanks!
MisterVoltio
