ANY home replacement work with contact widgets yet for droid x
The Moto contacts widget does resize in LauncherPro Plus. You have to create the widget, resize it, then add the contact data (email, phone, etc.). I believe it is a Plus feature only going by what I read on the developer's website.
I just tried it again, have you tried this or you think it does. I add the widget and its a larger picture and when you resize it the picture never changes its size and the shortcuts stay with the plus to add, even though when I click on them again, the ones I had clicked are no longer there, like they have been added (damn thats a run on sentence)
Can you confirm that youve used them and they work bc Ive tried and they act the same way they did on the previous updates. I tried 0.7.4. and it shows the picture but wont resize or do anything. I had been reading that they wont work at all, at least not now. Are there any other widgets out there that work similarly? tia
Yes i have tried it... you have to place the widget then add the data like sms/call/etc it only works if you have launcher pro plus though.
Yes, it works. I have it running on my DX. Do you have LauncherPro Plus? You need to cough up the extra $$ to get the resizing feature. Well worth the money.
See. This is a reason I love the forums on AC. I just dropped in today to catch up, and see that I can finally use the expanded MOTO contact widget. I like the LauncherPro Plus contact widget, but I actually prefer the MOTO contact tile widget better. Thanks!
Thanks! I deleted all the widgets and icons and then installed launcher pro and it works. Works perfectly!
Michael Carvalho
