Any Noticeable Difference Overclocking to 1.4 gHz
There is a new version out that has it now. Look in the bamf kernel thread by ADR.
With aosp roms you won't need to oc. They tend to fly without it and oc may result in random reboots. With bamf11 or soab i find ocing does reduce lag a little...or at least it seems to but keep an eye on phone temperature.
Also try different kernels as some may work better than others. Be sure they're compatible with your Rom though. Scope out the forums and you'll find what you need.
Sent from my ADR6400L using Tapatalk 2
ChrisAndroid
