Any options to compensate for only having 32 gb of internal storage on the Note 5?
A USB OTG flashdrive can be a good way to compensate for the non-expandable storage on the Note 5.
Additionally, Incipio may release an OffGRID case for the Note 5 that has an SD card slot, so you can have a larger battery and SD card slot just like on the 4. Bear in mind you can only use one or the other at a single time, though.
I guess you can start using cloud storage more. Pics, music and videos take lots of space.
Sent from my LG-H818 using Tapatalk
Here you go...
https://www.amazon.com/gp/aw/s//ref...ag=hawk-future-20&ascsubtag=UUacUvbUpU4665883
I have the menova and the scandisc both work perfectly with the Note 5. Just got the black menova yesterday and I love it. It's small compact and easy to keep on my Keychain and allows me to use all of my SD cards.
It may be a minor inconvenience to use it over having it inside the phone, but these are the best solution to use.
Posted from my Galaxy Note 5
yep this is what i have, the original 2.0 in 32gb and 64gb and the 32gb 3.0. works perfectly.
r3dpuk3
