Any Verizon Lollipop battery drains?
skatergirl
Retired Moderator
Mar 22, 2011
3,232
96
48
The Verizon page said to expect battery drain for a couple of days. I have gone through two batteries today. I am not sweating it though. I wiped the cache partition and if it is still draining after a few days I will just do a factory reset.
The battery drained quick during the update (obviously) but after the battery was great. Took it off the charger with 60% at 7pm and its 2am and the battery is at 35%. Moderate usage
Yes mine is draining a little faster than before on kitkat, even just in standby. I'll give it a couple days and see but I got a feeling a factory reset will be in my near future.
I installed the update last night; on standby the battery is fine, but as soon as I turned the screen on and did anything the battery just dropped way off. Less than an hour of screen-on time and the battery dropped ~25%. So I just pulled the trigger on a reset. Everything is backed up, so no big deal. We'll see how it works going forward.
I just went ahead and did the factory reset. I figured just to get it over with.
How are things after the reset?
I can see a small difference in mine, so it will prob smooth out n a couple days.
I did go ahead and do a factory reset after the updates, just to get it done on my day off
Factory reset is a pain but it does help especially after an update like lollipop. Just to see how my phone would be I did not do the factory reset and the battery was hot plus the drain was terrible, battery life went down by 20% w/in an hour. After the reset my phone seems way better and battery life has improved overall.
I have noticed standby is decent but yes as soon as I get the screen on and using it quick drain
No change either way. Phone has been acting normal since the update. The standby may be better but it's too early to tell. I don't do factory resets on my devices and luckily they all have been fine.
I agree on the "Standby" - I had it fully charged when I went to bed and it was at 98% when I got up. Never before - usually 88% - 90% after an overnight standby! The rest, too soon to tell - using it too much checking everything out! :cool:
My battery life has been horrible since the upgrade. I'm going to try wiping the cache before going the reset route.
