Any way to completely disable Bixby??
Are you on Verizon, like me? Maybe it's a Verizon thing...
Anyone else out there on Verizon that was able to get the button re-mapping to take on the BK Disabler? Still nothing from the devs...
Okay, I figured it out. Basically had to un-disable everything Bixby and then just go into the settings and do the Bixby remap. Now it works. I thought I had to do both. I have chosen to have the button bring up Contacts. I should probably have it be Facebook since that is the most used app but I just can't bring myself to do that!
Hi,
Visited before looking for a solution. Finally found it myself. I went through and completely disabled all bixby functions in settings/apps/systemapps. That didn't help as some things are not able to be disabled so I turned off all permissions to all bixby apps cleared all their storage and disabled background data and even disabled advanced features on the bottom. I'm not sure which one disabled the alarm gimmick but after clicking disable to the apps you can actually disable it didn't fix it so it's one of the permenant apps
I did not disable bixby vision because I use it once in a while. It doesn't affect anything.
If you don't use bixby then just disable everything
Riyan75
